Brief Description: Riveted the doubler to the right wing spar
1. Clecoed the doubler and shims in place. 2. Mel bucked while I used 5/32-10 rivets to attach the doubler and shims to the web. I riveted from the rear. 3. Following past procedures with Gary's rivet pounder, I set the 3/16-16 rivets to attach the doubler to the spar caps. With hind sight, it might have looked better if I had riveted the bottom spar cap from the front, with the manufactured rivet heads on the doubler. Oh well.
