Brief Description: Drill piano hinge attach holes to #30
1. Removed clecos and bolts so that I could remove the balance weight arm from the aileron ribs.
2. Replaced the balance arm ribs, and clecoed the aileron back together, including the aileron half of the piano hinge.
3. Drilled 1/8 & #30 the pilot holes to attach the piano hinge and the front angle to the aileron, as shown in Fig. 1.
4. Removed most of the clecos, leaving just enough to keep the assembly tight.
5. Put the left aileron aside so that I could repeat this process with the right aileron. It will be a bit more complicated because of the aileron trim option (ATO) assembly.
