Brief Description: Drill extra hole for AN3 bolt in extrusion & prime
1. I drilled (1/8", 11/64", and 3/16" reamer) the extra hole through the spar cap between the last two planned holes in the extrusion for the AN3 bolt, as suggested in the 7/23 log entry. The new hole gives a nice tight fit to an AN3 bolt. There is room for the bolt right beside a nose rib angle. I used the drill press to make the holes normal to the spar cap.
