Terrences Web Site
CH601XL
Wing Upgrade
7-23-2010
Remove rivets--continuation
Continuation because of Kitlog Pro's (#$&^%*%$#&) 2048 character limit:
2. To remove the stubborn rivets, I used the following procedure:
- Transfer punch the center of the rivet
- Drill through the center of the rivet with a 1/8" bit, being very careful to keep the drill normal to the spar cap and centered in the hole
- Enlarge the hole to 5/32"
- Drive the core of the rivet out with the 3/16" rivet gun punch
- Then drill again with a #11 bit to remove most of the residual material left on the walls of the hole.
- After I separated the bars and web of the spar cap, I used a pick to remove any remaining rivet shank material
CH601XL Home
739
Shop Setup
Training/info resour
Wing Upgrade
63
213
247
