Terrences Web Site
Date:  3-19-2010
Brief Description:  Drill solid rivet heads on R wing spar
Using Brown's rivet removal tool I drilled out the heads of the 3/16" rivets, as well as, the 5/32" rivets that needed to be removed. The jigs described in the 3/18 entry worked perfectly to hole the spar in position.
Spar in position for driilling
