Brief Description: Readjust spar angle using template
1. I used my torpedo level and the center spar template to check the spar angles that I had previously set using the angle finder. To my surprise, I found that the previous angles were off by 1.5-2°, and that the rear spar had to be elevated an additional ~0.35" to achieve the required 9° angle on the spar.
2. Tomorrow I will cut some new shims to put under the rear spar bar for the corrected angle.
