Brief Description: Clean stab parts and prime joint areas
I washed the stab parts in warm simple green solution as described in 7/1/07 entry. Unfortunately, I forgot to go over the joint areas with the new 7447 ScotchBrite that I bought. I had to be careful to avoid scrubing off the identifying and orientation marks that I wrote onto the parts with a Sanford Sharpie Marker. I'm not sure what's the best way to avoid this problem. A 1st approach would be to try to mark in areas away from the joint areas that will be primed. They thorough cleaning is not so important.
I primed the joint areas with Cortec 373 and let dry, 1st outside in the 90° heat and then in the factory overnight.
