Terrences Web Site
Date:  4-1-2008
Manual Reference:  6W8A 12 - 6W8B 1
Brief Description:  Drill main spar pilot holes, etc.
1. Put a plywood strip in place to protect the bottom of the main spar, and drill a new line of pilot holes, 3/32". See Fig. 1.
2. Mark the nose point of the nose ribs for the right wing.
3. Drill a 1.25" diameter hole into nose rib 3 for removing the fuel screen.
4. Position and drill #30 the gascolator mounting channel between nose ribs 2 & 3. See Fig. 2.
5. Mark the location of the hole for the gas line to pass through rib 2.
6. As near as I can tell without having the wing skin on, there should be room above the access cover to mount a spring loaded door that would allow one to drain the gascolator. The door might be the commercially available door from Camloc. See Fig. 3.
New line of pilot holes for spar
Gascolator mounting channel (upside down)
Camloc access door
Camloc access door
