Terrences Web Site
CH601XL
N/A
Begin build of gascolator mount channel
1. Cut .025 blanks, 90 x 200-mm., See Fig. 1.
2. Bend at 22-mm from each end, giving web width of 157-mm as was done for the pump channel.
3. Cut 61-mm diameter hole with fly cutter.
4. Drill 3/16" holes in gascolator tabs for
4. File notches in in the forward and reaward edges of the hole to clear the bowl bale so that the bowl can be removed for maintenance.
5. Cut the L-angle reinforcements to length.
6. Drill & cleco the L-angles.
7. Cut notches into the L-angle to clear the bale.
8. Deburr, scour, and prime the parts.
Design drawing
Channel & fly cutter
Gascolator clecoed to channel
CH601XL Home
739
Shop Setup
Training/info resour
Wing Upgrade
63
213
247
