Terrences Web Site
Date: 1-28-2008
Number of Hours: 4.00
Manual Reference: 6W3, 6W5 1-4
Brief Description: Drill, cleco, & rivet wing spar tips to main spars
I have decided to build the right wing first. That way, I won't need to get the pitot tube quite as soon.
1. Identified right & left spars. Working on the right spar:
2. Drilled & clecoed 3/32", 1/8", and #20 the right wing tip to the spar.
3. Cut a piece of L-angle to 230-mm, and then marked it for 7 holes at 35-mm pitch. The dwg. called for 40-mm pitch. But the spacing was such that the choice was35 or 42-mm pitch, and I chose 35-mm and 7 rivets.
4. Drilled & clecoed 3/32" & #30 the L-angle to the 45° end of the spar tip.
5. Measured the location for the rear rib (RR)-9 rivet line (3150-mm from the bottom of the inboard end of the spar per Dwg. 6W5). Marked the location for 6 holes@38-mm pitch. Drilled 3/32" pilot holes on the drill press.
6. Deburred, scoured, washed w/ lacquer thinner, and primed the joint line between the wing spar and the spar tip.
7. Riveted A5 the spar tip to the spar.
8. Repeated steps 2-6 on the left spar. The left spar will now go into storage, probably until I finish the right wing.
6. Clecoed A5 & riveted the right spar tip to the spar. See Figs 1, 2, & 3.
Right wing spar tip
Right wing spar tip_2
Right wing spar tip_3
