Terrences Web Site
CH601XL
N/A
Servo & control horn install
1. Worked out the alignment for the servo.
2. Drilled the servo to outside top skin, 1st #/32", then #30. See Fig. 1.
3. Pilot drilled the control horn and drilled the pin hole out to 1/8".
4. Installed the trim tab onto the aileron to mark the control rod center line.
5. Drilled & clecoed the control horn to the trim tab.
6. Riveted the trim tab to the control horn. Forgot to scour and prime the contact areas. See Fig. 2.
CH601XL Home
739
Shop Setup
Training/info resour
Wing Upgrade
63
213
247
