Brief Description: 2nd entry for 12/23 because of bug in Kitlog Pro 2
CAUTION: Kitlog Pro 2.0 discards the end of long descriptions without warning!
Reentry of the last part of previous entry to correct for data lost because of the undocumented bug in Kitlog Pro 2.0.
9. At one end of the hinge, I measured the height of the open hinge above the edge of the front of the elevator and marked that height on the the rule.
10. Drilled and clecoed the hinge at the location of each rib, carefully measuring and holding the hinge to the correct height.
11. Drilled and clecoed every other hole on the hinge. See Fig. 3 in previous entry.
