Because of some unexplained bug in KitLog Pro 2.0, I was unable to save the last few sentences from the previous log entry, so I'll try to reenter them here, as best as I can remember them.
5. Installed a 0.75" square cable mount (SteinAir p/n AS-ZMB) on the elevator rib to support the connector. Nuckolls had suggested that the connector was light enough to just let it hang on the wires. However, I was more comfortable using a stick-on cable mount and a cable tie to support the connector. I added a second cable mount. Since there is not much load on these mounts, I think they will probably be on for the life of the airplane (Long may it fly!)
6. Installed an MS21919-WDG3 clamp on the front-inside of the elevator to provide stress relief and support for the cable. After installing this clamp, I believe that the clamp w/o wedge would be easier to install, and would provide perfectly adequate support for cable. The wedge version might be better if there are individual wires in the bundle.
