Terrences Web Site
CH601XL
6T6 5-6
Install elevator trim tab hinge
1. Shortened trim tab hinge pin and drilled the ends of the hinge for safety wire.
2. Positioned the hinge into the elevator and drilled #40 and clecoed the hinge in place.
3. Positioned the trim tab onto the hinge and drilled #40 and clecoed the trim tab in place.
4. Checked for freedom of movement and alignment of trim tab with elevator.
5. Drilled hinges out to #30 for A4 rivets and clecoed.
CH601XL Home
739
Shop Setup
Training/info resour
Wing Upgrade
63
213
247
