Brief Description: Drill and cleco top rib, fit aft skin
Regarding the aft skin fit, the position of rib 3 on the spar is a bit too low, with the result that the prepunched holes in the skin are not over the drill line close to the spar. I queried ZAC about this situation. One lesson is that I need to read both the rudder build instructions that came with the rudder kit, as well as, the description of rudder instllation on the CD.
CALLED ZAC: asked Caleb whether the closeness of the holes to the edge on rib 3 would be a problem. Caleb said that it should not be a problem. Note that the edge distance varies from about 5-mm to 10-mm along rib 3.
