Brief Description: Disassemble center spar for upgrade--rear
1. lay the spar section flat on the table and drill the manufactured rivet head using rivet removal tool, shis time with the 5/32" positioner and 5/32" bit. 2. Knock off the rivet head with a cold chisel and hammer. 3. Clamp the web and spar caps onto the jigs, and drive out the rivet shanks with a rivet gun and a 1/8" punch. 4. As with the front section, the punch jumped off a couple of rivets, leading to some small dents in the cap that will have to be removed.
