Brief Description: Fill misdrilled 3/32" holes in web and doubler wit
Before installing the doubler to reinforce the damaged spot on the left spar web, I wanted to plug a row of 3/32" holes on the doubler and the web that I had mistakenly drilled just outboard of the holes for nose rib no. 3. I cut AN470-3-6 rivets down to -3's. The 2X rivet gun at 45 psi seemed about right to plug the holes.
