Terrences Web Site
Date: 11-30-2012
Number of Hours: 4.00
Brief Description: Prepare doubler for right wing spar
As noted previously, while working on the wing spar upgrade, I damaged the web of both wing spars. One suggested solution was to add a doubler that would be riveted to the web and then joggled so that it could be riveted to the spar caps. The problem is that I was not confident of bending the 0.040" thick doubler for the joggle. I took the spars over to Helena on 10/17 so that I could discuss the repair with EAA Technical Counselor, Clayton Wilhelm. Clayton suggested that I avoid the joggle by just putting a 0.25" shim between the web and the doubler. What a great idea!
1. A week ago I began implementing the repair on the right spar by cutting the shims from a 0.25" thick 6061 aluminum bar. The shims were 25x135 mm. After sawing them with my skill saw, I filed the edges smooth.
2. For the doubler I decided to use a piece of 0.040 6061T6 that was already cut to 200x100-mm. There was plenty of edge distance for the rivet holes through the spar caps.
3. I clamped the shims in place to the front of the spar web and marked the shims with the location of the holes that I had drilled per Zenair's suggestion back in June 2010. I drilled the marked holes 3/32" & 1/8" on the drill press. Then I clecoed the shims to the web and enlarged the holes to #20 for 5/32 rivets, carefully matching the existing holes in the web. See Fig. 1.
4. I clamped the doubler to the spar & drilled (3/32", 1/8", & #20) opposite corner holes through the existing web rivet holes. Then I clecoed and drilled the remaining web rivet holes through the doubler.
5. Finally, I drilled (3/32, 1/8", & 3/16") holes through the doubler matching the existing rivet holes in the spar caps. See Fig. 2
Shims clecoed to web
Shims and doubler clecoed to spar
