DAVID'S WEB SITE
Date:  4-7-2016
Number of Hours:  8.00
Manual Reference:  21.2.E.8
Brief Description:  INSTALLLING THE NOSE GEAR DOOR ACTUATOR
1 Match drill the plunger mount plate tothe firewall. The plate should be centered across the nose wheel tunnel and parallel tothe aircraft waterline.
2 Attach the plunger mount plate to the firewall. The plate should be installed after the fireproof blanket has been attached to the firewall.
3 Seal the bolt penertrations with RTV sealant to prevent pressure leaks.
4 Attach the nose door plunger mount onto the door plunger plate.
5 Insert the gas spring into the nose door planger mount and loosly hold the spring in the mount using the attachmnet hardware. Do not tighten the screws until the final adjustment of the nose gear doors has been completed.
6 With the cross-t aligned parallel to the firewall and the two nose gear plunger arms hanging vertically, determine the location of the actuator brakets on the nose gear door stiffeners.
7 Match drill the actuator brackets to the nose gear door stiffeners and attch them using bolts, washers, and locknuts.
8 Adjust the length of the plunger arms and the position of the gas spring in its mount until the doors open and close porperly. With the gas spring fully extended there should be no pressure on the nose gear doors. When closed, the nose gear doors should be snug, but not so tight as to cause undue pressure or deformation of the doors.
9 Tighten the jam nuts on all the adjustable rod ends and links as well as the bolt nd locknuts holding the gas sring into its mount tocomplete the installation.
