DAVID'S WEB SITE
Evolution
21 nose gear
4-7-2016
21.2.F.5
UP MICRO SWITCH
1 Swing the nose gear to the fully retracted position.
2 Find the loction for the switch that will cause the switch to close when the nose gear is retracted.
3 Match drill the switch to the uostop brce then attach using the hardware provided with the switch.
4 Connect the switch to the electricl harness.
5 Lower and retract the nose gear several times to test the action of the switch.
Evolution Home
1207
10 fuselage
11 hyd sys
12 fuel sys
13 brake sys
14 seat/saet belts
15 main door
16 heat/vent/air con
17 baggage door
18 pitot static
19 elec and avionics
20 auto pilot
21 nose gear
3 horizontal stab /
31 ice rain protecti
4 rudder
5 wings
6 flaps
7 aileron
8 landing gear
9 gear doors
duplicate inspection
