DAVID'S WEB SITE
Date:  4-7-2016
Number of Hours:  8.00
Manual Reference:  20.2.A.2
Brief Description:  ROLL SERVO
THE ROLL SERVO MOUNTS INSIDE THE AFT SHEARBOX ON THE AFT FACE ON THE PILOTS SIDE OF THE AIRCRAFT.
1 Trim excess material off the two pieces of the roll servo mouting bracket, ( 209-0159)
2 Using the full size template to drilland make the cutout in the mounting bracket for installation of the roll servo.
3 Align and clamp the two pieces together. Match drill and install two cleco fasteners tohold the pieces together. remove the clamp.
4 Position the servo bracket against the fact of the shearbox . Measur 3 1/4 " in from the right side of the shearbox and 3 7/8 " down form the top of the shear box. Position the bracket in place t this location ( hold th bracket temperally in place with cleco fasteners)
5 Using hysol bond the two brcket halfs together and in plce on the aft face of the shearbox.
6 Set the ailerons to neutral .
7 Combine the GSA 80 servo actuator GSM 86 servo gearbox and the clutch cartridge kit into an assembly.
8 Install the roll srvo and the servo limiter.
9 Install the servo arm.
10 Attach the roll control rod assembly.
12 Remove the neutral pinss from the control sticks and unclamps the elevatos.
13 Verify the travel of the ailerons and the rotation of the servo by moving the control rod trough its rnge of travel. Adjust the control rod ends as required.
