DAVID'S WEB SITE
Evolution
19 elec and avionics
4-7-2016
19.2.I
COMPASS
tHE FOLLOWING IS THE INSTALLATION PROCEDURE FOR INSTALLATION OF THE COMPASS.
COMPASS IS NOT BEING INSTALLED AS IT IS PART OF THE AVIONIC INSTRUMENT PANEL.
Compass should be installed on the glarshield i a location decided by the buider.
1 Match drill the mounting bracket to the glareshield.
2 Countersink the holes in the bracket.
3 Attach the mouting bracket to the glareshiled using screws and washer and nuts.
4 Install the compass into the mounting bracket.
NOTE
All attachment hrdware must be brass ( non magnetic)
Evolution Home
1207
10 fuselage
11 hyd sys
12 fuel sys
13 brake sys
14 seat/saet belts
15 main door
16 heat/vent/air con
17 baggage door
18 pitot static
20 auto pilot
21 nose gear
3 horizontal stab /
31 ice rain protecti
4 rudder
5 wings
6 flaps
7 aileron
8 landing gear
9 gear doors
duplicate inspection
