IN THIS CHAPTER YOU INSTALL ALL FOUR SEATS IN YOUR EVOLUTION. THIS PROCESS INCLUDES INCORPORATING SLIDER MECHANISMS FOR ADJUSTING THE PILOT'S AND CO-PILOT'S SETS. IN ADDITION, YOU WILL INSTALL THE SEAT BELT ANCHORS FOR THE SHOULDER HARNESSES.
STEPS TO COMPLETION
FRONT SEATS: * ATTACH THE SEAT BELT BRACE AND BRACKE TO THE MOUNTING PLATES. * LOCATE THE SEATS ON THE FORWARD SHEAR BOX AND DRILL ATTACHMENT HOLES. * MAKE SCREW AND BOLT HARDPOINTS IN THE SHEAR BOX. * MAKE THE SEAT BRACE RELEASES. * INSTALL THE MOUNTING PLATES. * INSTALL THE SEAT BELT SHOULDER HARNESS ANCHORS. * INSTALL THE SEATS.
REAR SEATS: * INSTALL THE MOUNTING BLOCKS. * INSTALL THE SHEAR BOX REINFORCEMENT FLANGES. * INSTALL THE REAR SEATS TO THE MOUTING BLOCKS. * INSTALL THE SEAT BELT SHOULDER HARNESS ANCHORS (OPTIONAL).
QUANTITIES INCLUDE ALL MOUNTING HARDWARE FOR THE SEATS.
INSTALLATION NOTES - the front seat mounting plates and the rear seat mounting blocks cannot be installed, or removed, if the wings are inserted into the fuselage.
- all hardware that installs inside the shear box needs to be low clearance.
- any location where you cannot use locking hardware, use Loctite.
