DAVID'S WEB SITE
Evolution
14 seat/saet belts
4-1-2016
14.2.F.3
PASSENGER SHOULDER HRNESS
1 DETERMIN THE LOCATION OF THE PASSENGER AND PILOTS SHOULDER HARNESS ATTACHMENT POINTS ON THE FUSALAGE. REF TO FIG 14.2.F.6
2 CUT A 3" HOLE AT THE CENTRE OF THIS LOCATION. CUT ONLY THE INNER SKIN OF THE FUSALAGE.
3 REMOVE AND CORE OUT THE AREA.
4 SURFACE PREP THE FUSALAGE IN THAT AREA USING 80 GRIT SANDPAPER. THOUGHLY CLEAN HE AREA.
5 RADIUS THE PERIMETER OF THE HOLE USING A NIX OF RESIN AND FLOX MIX.
6 AFTER CURING COVER THE INTERIOR OF THE HOLE WITH 2 BID (45.45) OF CARBON LAYUP EXTENDING 1" BEYOND THE HOLE.
7 ENSURE ALL AIR BUBBLES ARE WORKED OUT OF THE AREA.
8 ALLOW TO FULLY CURE.
9 USING A FLOX MIX BOND A FENOLIC BLOCK OF G10, 3/8 TO THE RESESEND AREA.
10 ALLOW TO FULLY CURE.
11 COCER THE DISC WITH A 2 BID (45.45) CARBON LAYUP.
12 APPLY PEEL PLY. AFTER CURING REMOVE THE PEL PLY.
INSTALL THE REAL HARNESS INERTAIL REEL USING AN960-516) WASHERS AND AN365-524A) NUTS.
13 ALL LAP BELTS SECURE TO THE SEAT BELT BRACT ON THE SEAT FRAME.
Evolution Home
1207
10 fuselage
11 hyd sys
12 fuel sys
13 brake sys
14 seat/saet belts
15 main door
16 heat/vent/air con
17 baggage door
18 pitot static
19 elec and avionics
20 auto pilot
21 nose gear
3 horizontal stab /
31 ice rain protecti
4 rudder
5 wings
6 flaps
7 aileron
8 landing gear
9 gear doors
duplicate inspection
