DAVID'S WEB SITE
Evolution
14 seat/saet belts
4-1-2016
14.2.K
INSTALLING THE SEATS
INSTALLING THE SEATS , CAN BE IN ANY ORDER. IT IS PROBABLY BEST TO INSTALL THE REAR SEATS FIRST.
REAR SEATS
1 POSTION THE FOUR DOVETAILS ON TH BOTTOM OF THE SEATS. OVER THE FOUR DOVETAIL BLOCKS.
2 INSEAT THE DOVETAIL AND SLIDE THE SEAT FORWRD INTO THE BLOCKS.
3 TIGHTEN TE LOCKING LATCH ON THE FRONT DOVETAILS AND LOCK THE SEAT IN PLACE.
FRONT SEATS.
1 REMOVE THE BOLT ( AN3-3A) AND THE WASHERS (AN970-3) FROM THE FRONT OF EACH SEAT RAIL.
2 INSERT THE SEAT RAILS INTO THE REAR PILLOW BLOCKS AND SLIDE THE SEAT FORWARD THROUGH THE FRONT PILLOW BLOCKS.
3 RE-INSTALL THE BOLT AND WASHERS INTO THE END OF EACH SEAT RAIL.
Evolution Home
1207
10 fuselage
11 hyd sys
12 fuel sys
13 brake sys
14 seat/saet belts
15 main door
16 heat/vent/air con
17 baggage door
18 pitot static
19 elec and avionics
20 auto pilot
21 nose gear
3 horizontal stab /
31 ice rain protecti
4 rudder
5 wings
6 flaps
7 aileron
8 landing gear
9 gear doors
duplicate inspection
