DAVID'S WEB SITE
Evolution
13 brake sys
3-31-2016
13.2.A
OVERVIEW OF THE BRAKE SYSTEM
NOTE
REFER TO BRAKE SYSTEM SCHEMATIC FOR SYSTEM LOCATION
MASTER CYLINDERS.
PILOTS SIDE
UPPER PORTS-CONNECT TO THE PARKING BRAKE VALVE.
LOWER PORTS- CONNECT TO THE UPPER PORTS OF THE CO-PILOTS MASTER CYLINDER.
THE CO-PILOTS
UPPER PORTS- CONNECT TO THE LOWER PORTS OF THE PILOTS MASTER CYLINDERS.
LOWER PORTS- CONNET TO THE BULKHEAD FITTINGS ON THE BRKE FLIUD RESERVIOR ON THE FIRE-WALL
Evolution Home
1207
10 fuselage
11 hyd sys
12 fuel sys
13 brake sys
14 seat/saet belts
15 main door
16 heat/vent/air con
17 baggage door
18 pitot static
19 elec and avionics
20 auto pilot
21 nose gear
3 horizontal stab /
31 ice rain protecti
4 rudder
5 wings
6 flaps
7 aileron
8 landing gear
9 gear doors
duplicate inspection
