DAVID'S WEB SITE
Evolution
13 brake sys
3-31-2016
13.2.G.1
INSTALLING THE BRAKE ASSEMBLIES
1 REF TO CHAPTER 8MAIN LANDING GEAR SECTION 8.2.F INSALLING THE WHEEKS AND BRAKE FOR INSTALLATION OF THE TORQUE PLATE, BRAKE DISC, WHEEL SPACER.
2 SLIDE THE BRAKE PADS BETWEEN THE BRAKE DISC AND THE WHEEL.
3 WHILE HOLDING THE BRAKE PADS IN PLACE, SLIDE THE CALIPER INTO ITS SEAT IN THE TORQUE PLATE.
4 INSERT THE FOUR BOLTS ( AN4H-17A) THROUGH THE CALIPER AND THREAD THEM INTO THE BRAKE PADS. TORQUE 85 -90 IN-LBS. AND SAFETY WIRE
NOTE WHEN THE DISC LININGS WEAR TO THE FOLLOWING THICKNESS THEY MUST BE REPLACED.
DISC (ROTOR) MINIMUM THICKNESS 0.312
LINING ( PAD) MINIMUM THICKNESS 0.125
Evolution Home
1207
10 fuselage
11 hyd sys
12 fuel sys
13 brake sys
14 seat/saet belts
15 main door
16 heat/vent/air con
17 baggage door
18 pitot static
19 elec and avionics
20 auto pilot
21 nose gear
3 horizontal stab /
31 ice rain protecti
4 rudder
5 wings
6 flaps
7 aileron
8 landing gear
9 gear doors
duplicate inspection
