DAVID'S WEB SITE
Evolution
11 hyd sys
2-22-2016
11.2.P
FLUSHING THE HYD SYSTEM
THIS OPERATION IS REQUIRED AFTER INITIAL SYSTEM STARTUP AND EVERY ANNUAL INSPECTION.
1 RAISED THE AIRCRAFT ON JACKS.
2 SHUT OFF POWER SUPPY.
3 PULL THE HYDRULIC CB.
4 DUMP THE SYSTEM PRESSURE BY OPENING THE ENMERGENCY YPASS VALVE.
5 RELEASE ALL PRESSURE FORM THE ACCUMULATOR BY USING THE SHREADER VALVE.
6 REMOVE THE ACCUMULATOR
7 DISASSEMBLE AND CLEAN THE ACCUMULATOR USING ACETONE. THIS SET IS NOT REQUIRED ON INITIAL STARTUP.
8 REMOVE THE FILTER FROM THE HOUSING.
9 REMOVE THE CHECKV AND ATTACHED TUBING THAT ACTS AS A BYPASS FOR THE HYD FILTER.
10 CHECK AND CLEAN THE FILTER
11 REINSTALL TE FILTER INTO THE HOUSING.
12 REINSTALL THE CHECK VALVE
13 REMOVE THE AFT MANIFOLD, CAPPING AND OPEN LINES.
14 REMOVE ALL COMPONENTS FRON THE AFT MANIFOLD AND CLEAN USING ACETONE, A NYLON BRUSH.
15 REINSTALL THE COMPONENTS ONTO THE AFT MANIFOLD.
16 REMOVE THE HYD PUMP AND DRAIN THE RESERVIOR AND CHECK THE RESERVOIR FOR SEDIMENT OR CONTAMINANTS, REMOVE AS REQUIRED. AND CLEAN THE RSERVIOR.
17 DISCONNECT THE MAIN AND NOSE GEAR LINES AT THE GEAR. REINSTALL THE HYD PUMP AND FILL THE RESERVIOR,
18 RESET THE HYD CB AND RUN THE PUMP FLUSHING THE LINES, ENSUREING THE PUMP RESERVIOR DOES NOT RUN DRY.
19 CONTINUE ITEM 18 UNTIL ALL AIR HAS BEEN PURGED FROM THE LINES.
Evolution Home
1207
10 fuselage
11 hyd sys
12 fuel sys
13 brake sys
14 seat/saet belts
15 main door
16 heat/vent/air con
17 baggage door
18 pitot static
19 elec and avionics
20 auto pilot
21 nose gear
3 horizontal stab /
31 ice rain protecti
4 rudder
5 wings
6 flaps
7 aileron
8 landing gear
9 gear doors
duplicate inspection
