DAVID'S WEB SITE
Date:  2-9-2016
Number of Hours:  8.00
Manual Reference:  10.2.J
Brief Description:  RHINO 9700 NOVALAC PAINT
RHINO9700IS SED TOCOAT THR FUSALGE WITHIN THE COCKPIT PRESSURE VESSEL ONLY, TO PROVIDE CHEMICAL AND ABRASION RESISTANCE,FROM ACCIDENTAL SPILLS OF HYDRAULIC, BRAKE AND SUEL FLUIDS
1 ABRADE THE SURFACE TO BE COATED TO ACHIVE A 5 MIL PROFILE.
2 REMOVE ALL CONTAMINANTS SUCHAS DUST , OIL OR DIRT.
3 MIX , APPLY AND CURE THE COATING IN ACORRORDNCE WITH THE MANUFACTURERS INSTRUCTIONS, EXCEPT AS OTHERWISE INDICATED.
4 APPLY THE MIXED PRODUCT BY BRUSH OR ROLLER TO ACHIVE 15 MILS THICKNESS
5 ONCE THE FIRST COAT HAS TACKED, BUT NOT FULLY CURED, APPLYAN ADDITIONAL 15 MIL COATING.
6 ALLOW THE MATERIAL TO CURE FOR A MINIMUM OF 48 HOURS BEFORE EXPOSURE TO ANY CHEMICALS. THE PRODUCE WILL COTINUE TO CURE FOR 7 DYS TO FULLPROPERTIES.
