DAVID'S WEB SITE
Date:  5-16-2015
Number of Hours:  4.00
Manual Reference:  5.2.L
Brief Description:  INSTALL STATIC WICK MOUNINT BRACKETS
LOCATE STATIC WICK MOUNTING BRAKET TO UNDERSIDE OF WING.
THEY MUST BE MOUNTED SO THEY ARE PARALLEL TO THE DIRECTION OF FLIGHT.
LOCATE FLIGHT REFERENCE LINES ON WING.
MEASURE FROM THE REFERENCE LINES PARALLEL , GIVING REFERENCE, LINE FOE THE STATIC WICK BRAKETS.
PREP AREA WITH 80 GRIT SAND PAPER. CLEAN WITH ACETONE.
BOND STATIC WICK BRACKET IN POSTION WITH HYSOL.
COAT AREA WITH CONDUCTIVE PAINT.
