DAVID'S WEB SITE
Date:  5-16-2015
Number of Hours:  4.00
Manual Reference:  5.2.P
Brief Description:  OAT PROBE INSTALL
THE OAT PROBE IS INSTALLED INSIDE THE WING TIP AND THROUGH THE ACCESS PANEL OF THE RIGHT WING.
ENSURE THAT THE LOCATION WILL NOT INTERFERE WITH THE COMPONENTS OF THE FUEL VENT SYSTEM.
DRILL A 5/16 HOLE THROUGH THE ACCESS PNEL, CORRESPONDING TO TE CHOSEN POSITION.
INSERT PROBLE THROUGH UNDER SIDE OFF THE PANEL, SECURE USING THE MANUFACTURERS INSTALLATION HARDWARE.
CONNECT PROBE TO WIRING HARNESS
REINSTALL ACCESS PANEL
