DAVID'S WEB SITE
Evolution
4 rudder
5-16-2015
4.2.I
BRAKE MASTER CYLINDER
THERE ARE FOUR BRAKE MASTER CYLINDERS.
ATTACH BODY OFF MASTER CYLINDER TO THE FRAME OF THE PEDAL ASSEMBLE.
THREAD THE ROD END INTO THE END OF THE BRAKE MASTER. THE FARTHER IN THE ROD END IS THREADED IN THE MORE THE RUDDER PEDAL WILL TILT FWD. TOWARDS THE FIREWALL.
ADJUST PEDAL AS DESIRED.
ENSURE THERE IS A MINIMUM12 THREAD ENGAGMENT.
Evolution Home
1207
10 fuselage
11 hyd sys
12 fuel sys
13 brake sys
14 seat/saet belts
15 main door
16 heat/vent/air con
17 baggage door
18 pitot static
19 elec and avionics
20 auto pilot
21 nose gear
3 horizontal stab /
31 ice rain protecti
4 rudder
5 wings
6 flaps
7 aileron
8 landing gear
9 gear doors
duplicate inspection
