DAVID'S WEB SITE
Date:  5-16-2015
Number of Hours:  4.00
Manual Reference:  4.2.J
Brief Description:  RUDDER CABLE STAND OFF
INSTALL RUDDER CABLE STANDOFF BETWEEN FWD SHEARBOX AND THE FWD RUDDER CAPTASN.
CUT TRIANGLE OUT OF A PIECE OF 1/4 THICK G-10 PHENOLIC. HEIGHT AND WIDTH AS REQUIRED TO ALIGN THE RUDDER CABLE WITH THE FWD CAPSTAN AND BE BELOW THE FLOOR PANEL.
WHEN LOCTING THE STNDOFF ENSURE ADEQUATE DISTANCE FROM RUDDER TO ENSURE STANDOFF DOES NOT INTERFERE WITH THE MOVMENT OFF THE RUDDER CABLES.
PREPARE SURFACE AND APPLIE USING HYSOL ORFLOX.
AFTER CURING LIGHTLY SAND USING 80 GRIT. WIPE CLEAN WITH ACETONE. APPLY MICRO FILLET.
SECURE STANDOFF TO FUSALAGE WITH A 3 BID LAYUP, EACH SIDE EXTENDIG 2 INCH.
DRILL TWO HOLES IN STANDOFF AND RUN ONE CABLE SLEEVE THROUGH EACH HOLE.
