DAVID'S WEB SITE
Evolution
4 rudder
5-16-2015
4.2.K
RIGGING THE RUDDER
CLAMP THE RUDDER IN NEUTRAL POSITION.
THREAD CLEVIS OF TURBUCKLES SO THERE ARE FOUR THREADS SHOWING.
POSITION PEDALS SO THEY ARE NEUTRAL.
THREAD THE CABLE THROUGH A NICOPRESS SLEEVE (18-3-M) THE CABLE THIMBLE AND THE TURNBUCKLE EYE AND FORM A LOOP AT THE END OFF THE RUDDER CABLE.
THEM THREAD THE END BACK THROUGH THE NICOPRESS SLEEVE. ( DO NOT REMOVE ANY EXCESS CABLE AT THIS TIME)
PULL THE LEFT SIDE CABLE AS TAUT AS POSSIBLE. HOLD THE CABLE TENSION AND NICOPRESS SLEEVE IN PLACE USING A CLAMP.
REPEAT THE PROCEDURE FOR THE RIGHT SIDE CABLE
Evolution Home
1207
10 fuselage
11 hyd sys
12 fuel sys
13 brake sys
14 seat/saet belts
15 main door
16 heat/vent/air con
17 baggage door
18 pitot static
19 elec and avionics
20 auto pilot
21 nose gear
3 horizontal stab /
31 ice rain protecti
4 rudder
5 wings
6 flaps
7 aileron
8 landing gear
9 gear doors
duplicate inspection
