Orientation of th epitch trim module is not important, but must be mounted in a location within 30" from the forward edge of the aft floor so the wiring harness willhave an adequqte service loop when connected.
1 Deter mine a suitable loction for the pitch trim module within the area of the aft shearbox aft face, outside the shearbox.
2 Attach the trim module to the aircraft using stud mounts, washers, and nuts.
