DAVID'S WEB SITE
Evolution
19.2.N
GROUND BUS BLOCK AND PRIMARY BUS BLOCK
THESE BLOCKS ARE INSTALLED UNDER THE FLOOOR PANEL IN THE PILOTS FOOTWELL.
1 Make a mounting block out off g10 1/4 phenolic sheet the size of the block base.
2 Prepare mounting screws to attach the bus block to the phenolic base ( length as required).
3 bond the mounting block to the aircraft fusalage at the locations in fig 19.N.2.1.
4 After the flox has fully cured. Secure the bus blocks to the phenolic block bases.
Evolution Home
1207
10 fuselage
11 hyd sys
12 fuel sys
13 brake sys
14 seat/saet belts
15 main door
16 heat/vent/air con
17 baggage door
18 pitot static
19 elec and avionics
20 auto pilot
21 nose gear
3 horizontal stab /
31 ice rain protecti
4 rudder
5 wings
6 flaps
7 aileron
8 landing gear
9 gear doors
duplicate inspection
