DAVID'S WEB SITE
Date:  4-4-2016
Number of Hours:  4.00
Manual Reference:  16.2.H
Brief Description:  HVAC DRYER
The dryer is mounted aft off the rear preeusre bulkhead on the right side off the fusalage.
1 Make a mounting braket for the dryer. The braket shown ( fig 16.2.H.2 0 ) is made up of layup shaped as required and bonded to the fuslage using Hysol or Flox
2 Locate the mounting braket so the installed it will not interfere with the elevator push pull tube or the other components located in the area aft of the pressure bulkhead.
3 Installthe dryer with its axis vertical and the inspection window up .
4 Attach the dryer to the mounting braket using a clamp ( 145-0013)
