DAVID'S WEB SITE
Date:  4-4-2016
Number of Hours:  4.00
Manual Reference:  16.2. I
Brief Description:  FIREWALL CONNECTIONS
1 Install the expansion valve on to the evaporator coil.
note
all lengths are approimate. Adjust the lengths as required
2 Attach the vinyl tubing between the evporator drain fittings and the stainless steel tubing.Secure the tubing to the drain fittings and the tee using worm drive clamps.
