DAVID'S WEB SITE
Date:  4-1-2016
Number of Hours:  6.00
Manual Reference:  14.2.F.3
Brief Description:  PASSENGER SHOULDER HRNESS
1 DETERMIN THE LOCATION OF THE PASSENGER AND PILOTS SHOULDER HARNESS ATTACHMENT POINTS ON THE FUSALAGE. REF TO FIG 14.2.F.6
2 CUT A 3" HOLE AT THE CENTRE OF THIS LOCATION. CUT ONLY THE INNER SKIN OF THE FUSALAGE.
3 REMOVE AND CORE OUT THE AREA.
4 SURFACE PREP THE FUSALAGE IN THAT AREA USING 80 GRIT SANDPAPER. THOUGHLY CLEAN HE AREA.
5 RADIUS THE PERIMETER OF THE HOLE USING A NIX OF RESIN AND FLOX MIX.
6 AFTER CURING COVER THE INTERIOR OF THE HOLE WITH 2 BID (45.45) OF CARBON LAYUP EXTENDING 1" BEYOND THE HOLE.
7 ENSURE ALL AIR BUBBLES ARE WORKED OUT OF THE AREA.
8 ALLOW TO FULLY CURE.
9 USING A FLOX MIX BOND A FENOLIC BLOCK OF G10, 3/8 TO THE RESESEND AREA.
10 ALLOW TO FULLY CURE.
11 COCER THE DISC WITH A 2 BID (45.45) CARBON LAYUP.
12 APPLY PEEL PLY. AFTER CURING REMOVE THE PEL PLY.
INSTALL THE REAL HARNESS INERTAIL REEL USING AN960-516) WASHERS AND AN365-524A) NUTS.
13 ALL LAP BELTS SECURE TO THE SEAT BELT BRACT ON THE SEAT FRAME.
