DAVID'S WEB SITE
Date:  3-31-2016
Number of Hours:  4.00
Manual Reference:  13.2.E
Brief Description:  BRAKE LINES. PARKING BRAKE TO THE WINGS
ALUMINUM TUBING IS USED TO CONNECT THE PARKING BRAKE TOTHE BRAKE LINES IN THE WINGS.
1 ALUMINUM TUBING (1/4 DIA X 0,35 WALL. 5052-0) IS USED FOR THE BRAKE LINES FROM THEOUTLET PORTS OF THE PARKING BRAKE VALVE TO THE BULKHEAD FITTINGS IN THE LEFT AND RIGHT SIDES OF THE FUSALAGE. REF TO FIG 13.2.E.1
2 MEASURE THE LENGTH OF TUBING YOU WILL NEED INCLUDING THE EXTRA TO ALLOW FOR EXPANSION AND ROUTING AROUND FUEL AND HYDRAULIC LINES.
3 SLIDE NUT ( AN818-4D) AND SLEEVE ( AN819-4D) AS REQUIRED OVER THE TUBING PRIOR TO FLARING.. THIS MUST BE DONE FOR EACH END OF THE TUBING.
4 FLARE THE ENDOF THE TUBING. REF TO CHAPER TO FOR FLARING METHODS.
5 POSITION THE TUBING AND CUT OFF ANY EXCESS TUBING FOR SORRECT FITTING.
6 SECURE THE TUBING TO THE PARKING BRAKE VALVE AND TO THE BULKHEAD FITTINGS.
