DAVID'S WEB SITE
Evolution
12.2.D
GASCOLATOR/ FUEL FILTER
THE GASCOLATOR OUNTS TO THE FIREWALL FORWARD.
1 DRILL A 3/4 HOLE IN THE FIRWALL AT THE LOCATION SHOWN IN CHAPTER 23.
2 DECORE THE FIREWALL AROUND THE HOLE A MININMUM OF 1/2 AL ROUND.
3 COMPLETLY PACK TE DECORED AREA WITH FLOX.
4 ALLOW THE FLOX TO CURE A MINIMUM OF 24 HOURS.
5 RE-DRILL THE HOLE.
6 ENSURE THE FIREWALL BLANKET HAS BEEN INSTALLED ON THE FIREWALL PROIR TO INSTALLING THE GASCOLATOR/FUEL PUMP.
7 THREAD THE BULKHEAD FITTING INTO THE INLET PORT OF THE GASCOLATOR AND TIGHTEN IT UNTIL THE O-RING SEATS.
8 INSTALL A WASHER , AND INCERT THE BULKHEAD FITTING THROUGH THE FIRWALL BLANKET AND THE HOLE IN THE FUSALAGE.
9 ORIENT THE GASCOLATOR/ FUEL PUMPWITH THE INDICATOR UP.
10 SECURE THE BULKHEAD FITTING TO THE FIREWALL USING A WASHER AND A NUT THEN INSTALL THE REDUCER.
Evolution Home
1207
10 fuselage
11 hyd sys
12 fuel sys
13 brake sys
14 seat/saet belts
15 main door
16 heat/vent/air con
17 baggage door
18 pitot static
19 elec and avionics
20 auto pilot
21 nose gear
3 horizontal stab /
31 ice rain protecti
4 rudder
5 wings
6 flaps
7 aileron
8 landing gear
9 gear doors
duplicate inspection
