DAVID'S WEB SITE
Evolution
12.2.E
GACOLATOR/FUEL FILTER SERVICING
REMOVE THE FILTER ELEMENT FROM THE FILTER HOUSING. BY CUTTING AND DISCARDING THE LOCKING WIRE.
HOLD THE FILTER RETAINING NUT WHILE LOOSENING THE JAM NUT.
INSPECT THE FILTER ELEMENT FOR CONTAMINATION, AFTER INSPECTION CLEAN THE FILTER WITH SOLVENTAND GENTLY BLOW DRY WITH LOW PRESSURE AIR.
REPLACE THE FILTER ELEMENT IN THE HOUSING.
SECURE THE FILTER BOWL WITH SAFETY WIRE.
Evolution Home
1207
10 fuselage
11 hyd sys
12 fuel sys
13 brake sys
14 seat/saet belts
15 main door
16 heat/vent/air con
17 baggage door
18 pitot static
19 elec and avionics
20 auto pilot
21 nose gear
3 horizontal stab /
31 ice rain protecti
4 rudder
5 wings
6 flaps
7 aileron
8 landing gear
9 gear doors
duplicate inspection
