DAVID'S WEB SITE
Evolution
12.2.F
ELECTRIC FUEL PUMP
THE ELECTRIC FUEL PUMP MOUNTS FORWARD OF THE FIRWALL.
1 DRILL FOUR 3/16 HOLES IN THE FIRWALLAT THE LOCATION SOW IN CHAPTER 23 FIREWALL FORWARD.
2 MATCH DRILLTHE FUEL PUMP MOUNTING BRACKET TO THE FOUR HOLES.
3 SQUARE OFF THE SCREW HEADS AND BOND THEM TO THE FIRWALLUSING HYSOL OR FLOX. REF TO CHAPTER 2.
4 CUT FOUR SLOTS IN THE MOUNTING BRAKET, TWO ON EACH SIDE.
5 SLIDE THE HOSE CLAMPS THROUGH THE SLOTS SO THE FUEL PUMP MAY BE FIRMLY HELD TO THE MOUNTING BRACKET.
6 ENSURE THE FIREWALL BLANKET HAS BEEN INSTALLED ON THE FIREWALL PROIR TO INSTALLING THE MOUNTING BRAKCET.
7 ATTACH THR BRACKET TO THE FIRWALL USING WASHERS AND LOCKNUTS.
Evolution Home
1207
10 fuselage
11 hyd sys
12 fuel sys
13 brake sys
14 seat/saet belts
15 main door
16 heat/vent/air con
17 baggage door
18 pitot static
19 elec and avionics
20 auto pilot
21 nose gear
3 horizontal stab /
31 ice rain protecti
4 rudder
5 wings
6 flaps
7 aileron
8 landing gear
9 gear doors
duplicate inspection
