DAVID'S WEB SITE
Date:  2-29-2016
Number of Hours:  4.00
Manual Reference:  12.2.H
Brief Description:  FUEL LEVEL SENSORS
THERE IS A FUEL LEVEL SENSOR INSTALLED IN EACH WING. THESE SENSORS ARE APPROX 10" LONG AND WHEN INSTALLED PENERTRATE THROUGH THE WING RIB IN THE WET WING FUEL TANK. THEY ARE INSERTED INTO THE TNK THROUGH A PENERTRATION IN THE AIRCRAFT WHEEL WELL.
INSTALLATION.
1 SLOWLY INSERT THE FUEL LEVEL SENSOR INTO THE WING THROUGH THE THREADED BUSHING IN THE WHEEL WELL.
2 CARFULLY PUSH THE SENSOR THROUGHT HE BUSHING PENERTRATING EACH WING RIB.
3 COAT THE THREAD ON THE SENSOR WITH LOCTITE 567, PERMATEX 59235, OR EQUIVALENT THREAD SEALANT.
4 SCREW THE HEAD OF THE SENSOR INTO THE THREADED BUSHING I THE WHEEL WELL. TIGHTEN SNUG.
5 CONNECT THE ELECTRICAL COOENTORS.
6 COAT THE SCREWS AND ELECTRICAL CONNECTORS USING TRUCK-LITE CO., INC MULIT PURPOSE MAINTENANCE SPRAY, OR EQUIVALENT, FOR CORROSION PROTECTION.
