DAVID'S WEB SITE
Date:  2-23-2016
Number of Hours:  8.00
Manual Reference:  11.2.F
Brief Description:  INSTALLING THE ACCUMULATOR
THE ACCUMULATOR IS 3" IN DIAMETER.
1 FABRICATE TWO MOUNTING BRKETS APPROXIMATELY 2" WIDE, FOR SECURING THE ACCUMULATOR TO THE FUSALAGE
THE MOUNTING BRAKETS CAN BE MADE FROM A SINGLE LAY-UP,THEM CUT INTO SEPERATE UNITS TO THE DESIRED LENGTH.
2 APPLY RELEASE TAPE TO THE ACCUMULATOR BODY. LAY-UP2 BIDS OF CARBON FIBER HALFWAY AROUND THE ACCUMULATOR
3 PLACEA HOSE CLAMP CENTRED AROUND THE CARBOM LAYUP FOR EACH BRACKET
4 ADD 2 BID CARBON LAYUP OVER THE BACK SECTION OF THE HOE CLAMP AND THE FIRST BID LAYERS
AFTER CURING
5PLACE THE CLAMPS ON THE ACCUMULATOR IN THIER FINAL POSITION. THIS HOLD THE CLAMPS ALIGNED WHILE THEY BOND TO THE FUSALAGE.
6 MOUNT THE ACCUMULATOR TO THE FUSALAGE IN THE FOLLOWING POSITION.
AFT END OFF THE ACCUMULATOR IS 3" FORWARD OFF THE AFT PRESSURE BULKHEAD.
AS HIGH AS POSSIBLE ON THE FUSALGE WALL BUT JUST CLEAR OF THE UNDERSIDE OF THE BAGGAGE FLOOR.
7 BOND THE CLAMPS TO THE FUSALGE USING FLOX.
8 AFTER FLOX HAS SETUP MAKE A 2 BID LAYUP ACROSS THE FLANGES.
