DAVID'S WEB SITE
Date:  2-23-2016
Number of Hours:  6.00
Manual Reference:  11.2.H
Brief Description:  HYD FILTER AND CHECK V
THE FILTER IS INSTALLED BETWEEN THE HYDRAULIC RESERVIOR/PUMP UNIT AND CHECK VALVE MOUNTED IN THE AFT MANIFOLD.
1 INSTALL THE FILTER AND CHECK VALVE IN THE PIPING TO THE AFT MANIFOLD
2 MAKE A PLATFORM OUT OF A PHENOLIC, 8 BID E.GLASS. 08. G-10OR 8 BIB CARBON LAYUP TO MOUNT THE FILTER AND CHECK VALVE ON.
3 PLACE ADEL CLAMPS AROUND THE FILTER AND CHECK VALVE AND MATCH DRILL THROUGH THE PLACTORM TO ACCEPT SCREWS FOR THE CLAMP. LENGH OF THE SCREWS AS REQUIRED.
4 MOUNT THE FILTER AND CHECK VALVE ONTO THE PLATFORM.
NOTE
ENSURE DIRECTION OFF FLOW OF THE CHECK VAVLE ONTO THE PLATORM.
SET THE CHECK V TO 50 PSI USING MANUFACTURERS INSTRUCTIONS.
5 BOND THE PLATFORN TO THE FUSLAGE USING FLOX.
6 ATTACH THE PIPING CONNECTIONS TO THE FILTER AND VALVE BETWEEN THE RESERVIOR/PUMP UNIT AND THE AFT MANIFOLD.
REPLACE CARTRIDGE EVERY ANNUAL INSPECTION.
