DAVID'S WEB SITE
Evolution
11.2.P.2
FLUSHING THE ACTUATORS
THE ACTUATORSDO NOT NEED FLUSHING ON INITIAL STARTUP, BUT SHOULD BE FLUSHED ANNUALLY.
1 DISCONNEST THE ACTUATORS FROM THELANDING GEAR.
2 ATTACH HOSES TO THE UP AND DOWN PORTS, AND PLACE EACH HOSE INTO SEPERATE BUCKETS, FILLED WITH THE MATCHING AIRCRAFT HYD FLUID.
3 OPERATE THE ACTUATOR PISTON FLUSHING THE FLUID UPTO THE BUCKET ENSURING THE CLEAN FLUID IS MOVRD INTO THE ACTUATOR.
4 CONTINUE THE OPERATION UNTIL CLEAN FLUID IS SEEN COMING OUT OFF THE ACTUATOR.
NOTE
STRAIN THE FLUID FROM THE RETURN BUCKET AND CHECK FOR CONTAMINANTS.
5 RECONNECT THE HOSES TOTHE ACTUATORS.
Evolution Home
1207
10 fuselage
11 hyd sys
12 fuel sys
13 brake sys
14 seat/saet belts
15 main door
16 heat/vent/air con
17 baggage door
18 pitot static
19 elec and avionics
20 auto pilot
21 nose gear
3 horizontal stab /
31 ice rain protecti
4 rudder
5 wings
6 flaps
7 aileron
8 landing gear
9 gear doors
duplicate inspection
