DAVID'S WEB SITE
Evolution
10.2.B
INSTALLING THE FLOORBOARDS
MAKE THE FLOORBOARD INSTALLATION JIGS USING THE PROVIDED THE TEMPLATES.
1 CUT THE JIGS FROM 3/4" TO 1" THICK PLYWOOD. IT WILL BE NECESSARY TO BEVEL SOME OF THE CORNERS AND EDGES.
2 USE THE JIGS TOCREAT CARBON FLANGES WHICH SUPPORT THE FLOORBOARDS IN THE PROPER POSITION.
3 TRIM THE FLOORBOARDS USING THE PAPER TEMPLATES AND THE JIGS, TO FIT THE FINAL LOCATION.
4 DRILL HOLES USING THE PAPER TEMPLATES , MATCH DRILLING THE HOLES.
5 PUT HARDPOINTS IN THE FLOOR PANELS WHERE ANY ADDITIONAL SUPPORT NEAR THE CENTRE LINE.
FLOORBOARDS SHOULD BE SECURED TO THE FUSALAGE USING 4 BID LAYUPS 2: WIDE AND CUT THO LENGTH AS REQUIRED.
Evolution Home
1207
10 fuselage
11 hyd sys
12 fuel sys
13 brake sys
14 seat/saet belts
15 main door
16 heat/vent/air con
17 baggage door
18 pitot static
19 elec and avionics
20 auto pilot
21 nose gear
3 horizontal stab /
31 ice rain protecti
4 rudder
5 wings
6 flaps
7 aileron
8 landing gear
9 gear doors
duplicate inspection
