DAVID'S WEB SITE
Date:  11-9-2015
Manual Reference:  8.2.J
Brief Description:  ACTUATE THE GEAR USING HYDRAULICS POWER
1 REF TO CHAPTER 11 HYDRAULIC SYSTEM
2 STOP THE UPWARD MOTION OF THE GEAR FREQUENTLY AND CHECK CLEARANCES WITH THE AIRCRAFT AS YOU PERFORM THE GEAR SWING.
3 REPAT THIS STEP SEVERAL TIMES TOENSURE PROPER OPERATION OF THE GEAR.
4 VEARIFY ALL THE HARDWARE IS PROPERLY INSTALLED AND TORQUED AND THE ADJUSTABLE PIN BEARING IS INSTALLED WITH THE FACE OF THE PIN TOUCHING THE BEARING IN THE PILLOW BLOCK PLUS1/4 TURN WITH THE JAM NUT SNUG. SAFETY WIRE THE JAM NUT.
