DAVID'S WEB SITE
Date:  11-9-2015
Manual Reference:  8.2.K
Brief Description:  LANDING GEAR ACTUATOR LOCKED SENSOR
1 SUPPORT THE AIRCRAFT ON JACKS WITH THE GEAR CLEAR TO SWING.
2 TURN ON ELECTRICAL POWER AND PLACE THE GEAR SWITCH TO UP POSITION. MOMENTARILY APPLY A PRESSURE OF 1. 0 PSI OR LESS TOTHE PITOT TUBE TO UNLOCK THE DOWN LOCK POSITION.
WARNING.
DO NOT APPLY MORE THAN 1.0 PSI
3 VERIFY THAT EACH ACTUATOR IS UNLOCKED BY MOVING THE GEAR BACK ANF FORTH.
4 PULL LANDING GEAR INTO THE DOWN POSTION AND HOLD IN PLACE.
5 CONNECT MAIN GEAR POSITION SENSOR WIRING TO THE ELECTRICAL HARNESS AND THE NOSE GEAR POSITION SENSOR WIRING TO THE ELECTRICAL HARNESS.
6 SLIDE SENSOR 1/2 "INTO THE SENSOR MOUNT WITH THE WIRED END POINT TOWARDS THE ACTUATOR SHAFT. REF TO 8.2.K.1 ( ACTUATOR SENSOR AND MOUNT)
7 SLIDE THE POSITION SENSOR FURTHER INTO IT,S MOUNTING BRACKET UNTIL THE SENSOR,S LED ILLUMINATES. SLIDE THE SENSOR BACKOUT UNTIL THE LED TURNS OFF, THEN SLIDE IT OUT AN ADDITIONAL 1/16"
8 REPEAT STEPS 6 AND 7 FOR THE REMAINING TWO LANDING GEAR.
